QualiPSo Factory 0.6
The QualiPso Factory team would like to announce the release of QualiPSo Factory 0.6
QualiPSo Factory 0.6 is available for download.
We hope you enjoy using QualiPSo Factory! If you have any questions, please consult:
QualiPSo Factory 0.6 Release Notes
The full list of changes can be found in our issue management system, and is reproduced below.
Known Incompatibilities with previous release
  1. Database incompatible with version 0.5, no migration script provided.
Improvement
  1. Cleaning maven dependency tree to ease release and centralise external dependencies
  2. Renaming factory-package-basic into factory-assembly
  3. Changing context root from /factory-ui to /factory
  4. Updating archetypes
  5. First version of user guide for UI part
  6. Merging all factory-ui-* into one single factory-ui (merge of -qad branche)
  7. Lots of improvements in QGWT internal library (many new components, showcase)
  8. Removing GWT mosaic support
  9. Subversion UI module
  10. IssueTracker module integration
  11. Compelete semantic core integration including support for permissions management and SPARQL requests
  12. RDF view of resources implementation (linked data ready)
  13. FOAF ontology integration into membership module
  14. Identity Manager application integration (user creation)
  15. Complete Notification rewriting
  16. New EventQueue processing
  17. Some dependency update (jgit, sshd)
  18. Upgrade to JBoss 6 M2
  19. OpenParts UI framework upgrade
  20. Improvement of all service UI
  21. File upload and download implementation in Core
